Removal of SE side skirts and bump strips ?
oldroydsr4
Post Sat Oct 21, 2006 10:45 pm
Currently stripping car for paint &(rust removal), just wondering how do I remove the SE side skirts and bump strips?
Cheers for your help
appletree
Post Sun Oct 22, 2006 8:08 am
se side skirts have clips under neath on to the sill, so get a smallish screw driver and push each corner of the cilp looking from the back and it should relise. there is also a screw that holds the front section of the skirt to the front wing, so you need to remove the under seal and then remove that.
rubbing strips on the drivers door there is a screw a tthe handle end, undo and then gently prise it off, just those little pop in clips, same for the back quarter but no screw, i pushed these out from the inside using a small punch once i had removed the cover from inside.
have a look in the tech section and then go on the ETK, fill it in and find the rubbing strips and this will show you where the clips are, how many there are and what type they are.
you'll probably brake them getting them off as they do get quite brittle. :D
appletree
Post Sun Oct 22, 2006 8:12 am
here you go, i was board so i go it for you, its for my IS but you get the idea. click the pics to enlarge :D
http://www.realoem.com/bmw/partgrp.do?m ... g=51&fg=20
oldroydsr4
Post Sun Oct 22, 2006 10:26 am
cheers that is perfect.
