few questions
shazE30
Post Wed Oct 18, 2006 4:56 pm
hi all was wondering would a g reg 325i cab have abs fitted as standard as where the abs block would go mine is missing but there is the plug to connect it
2nd what is all the ratio business on an lsd iv got one from a 325i sport do i just swap it over to my diff or do i require further parts
and last but not least can any1one tell me i get a random squeeking or shuddering noise from my steering wheel when im doing a full lock turn or 3 point turn is this summing serious??? how do i sort it
hope you guy's can help cheers....shaz :D
orangecurry
Post Wed Oct 18, 2006 5:05 pm
1) I think they were standard - um from memory just behind the passenger headlight?
3) Brianmoooore would say 'check the PAS fluid level, and if there isn't enough in there, get some in fast and keep your fingers crossed'
shazE30
Post Wed Oct 18, 2006 5:10 pm
orangecurry.....thanx for the quick reply will be checking the fluid lets hope it is just that what could it be worst
case senario.......my abs block is defo missing will this affect the car in the long term??? iv been driving about fine
for quite a while now :?
jcjdavis1
Post Wed Oct 18, 2006 5:23 pm
Hi
No3 check pulley belt [if it has one]
oze30
Post Wed Oct 18, 2006 5:40 pm
2: You should just be able to swap like for like. no extra things ( unless you go from small to big case I think!)
3: Could be a ball joint or rod end for shuddering. (Your not in a multi story carpark are you? those polished concrete floors will give those symptoms too
shazE30
Post Thu Oct 19, 2006 11:41 pm
cheers guys.....any1 got info on ratio's on a lsd what will it do whats best for drifting :D
jmc330i
Post Thu Oct 19, 2006 11:48 pm
The LSD will most likely be a 3.64 or 3.91 if it came from a Sport.
James
'91 325i Sport
'93 318i touring 16v
shazE30
Post Thu Oct 19, 2006 11:49 pm
is that good or would a diffrent ratio be better :?
