windscreen replacement
keith52
Wed Mar 30, 2005 6:24 pm
i 've changed my windscreen recently (myself) which wasn't a problem, but what is is replacing the hard plastic centre which fits in the rubber itself , any suggestions on how to fit it , No great problem to take it to a fitter but i've got this far with it i'd like to complete the fitting Cheers keith
Ant
Retired Team Member
Retired Team Member
Wed Mar 30, 2005 6:57 pm
the guy that does Our screens at work usually gets someone to push on the screen from the inside to open the gap in the rubber a little.
not big or clever but it works and hes not broken one yet :wink:
keith52
Wed Mar 30, 2005 10:00 pm
thanks Ant, i;ll try that with ample washing up liquid i think Cheers Keith
Wed Mar 30, 2005 11:42 pm
There's a special tool to do this, ( only a diamond shaped piece of stiff wire ), that does this job in seconds.
Wouldn't know where to buy one, or possibly hire one though.
keith52
Thu Mar 31, 2005 6:49 am
i've actually got a complete fitting kit with various sized diamond shaped ends but nota clue on how to use it ! :eek: , They say a little knowledge is dangerous Cheers Keith
Project_E30
Thu Mar 31, 2005 7:59 am
keith52 wrote:i've actually got a complete fitting kit with various sized diamond shaped ends but nota clue on how to use it ! :eek: , They say a little knowledge is dangerous Cheers Keith
How long did it take you to change?
Would you mind sharing your knowledge?
keith52
Thu Mar 31, 2005 8:08 pm
Approx 5 mins to remove , take out the centre hard plastic which runs in the middle of the screen rubber firstlly removing the centre clip located in the middle of the rubber at the bottom of the screen, run thin screwdriver completely around the screen rubber to break any seal that may have formed . position blanket on the bonnet to protect the pait work , have someone you can trust to hold onto the screen while you pop inside the car and really carefully apply a little pressue on the screen either with you uppervbody weight or your feet and push out which will cause the screen to detach from the rubber , once you've got about a couiple of inches out the screen is easily removed replacement is the reversal but you don't have to use you body weight but a specilist tool which enables you to reposition the rubber over the lip of the screen, hardest part is replacing the centre plastic back into the rubber This is ok to do if you have the confidence in yourself
telski789
Thu Mar 31, 2005 9:43 pm
i need one of these specialist tools!!! where do i get one from?!!
Terry
keith52
Fri Apr 01, 2005 6:45 am
Should able to get from any good motor factor outlet
keith52
Sat Apr 02, 2005 7:31 am
Ant i've tried your suggestion but it does the opposite it closes the rubber together , i've worked out how the diamond shaped tip works it spreads the rubber apart but where do i start installing the plastic insert Cheers Keith
Sat Apr 02, 2005 10:52 am
At one end?
keith52
Mon Apr 11, 2005 6:25 am
bump , still after an answer anyone please :?
khan325i
Tue Apr 12, 2005 4:17 pm
hi there interesting subject, i have the tool for this
its made buy BODYLINE & its called a WEATHER STRIP removel tool
i bought mine about 1year ago for about Ԛ£15 if i remember correctly dont hold me to that price
oh ya i bought it from brown brother, find out from you directry for your local one
hope thats some help
keith52
Tue Apr 12, 2005 4:21 pm
Cheers khan , ive got the tool but don't know where to start .
:oops: Keith
johnono
Tue Apr 12, 2005 5:04 pm
i had my windscreen replaced today..160 fitted :oops:
as i was standing right nezt to him as he did it iԚ´ll write what i saw
.slid the black clip over to the left
.got the triangle tool and ran it round the inside of the windscreen and weatherstrip
.peeled out the weatherstrip from the right
.he got in while his mate held down on the screen from outside
.the screen pushed out very easily
.degrased the inner seal, positioned the new screen on the inner seal
.Ԛ´edged inԚ´same weatherstrip (dependant on condition of course) and given a moisturising spray before re-inserting the strip
.smoothed in from left to right, clip slid back over to cover gap in the weatherstrip
and that was it.
i noticed the special edged tool, but his mate had a totally different looking one and he did an edge on my window so i think its not soo important, having the experience is :?
Tue Apr 12, 2005 8:28 pm
Be carefull not to stretch the strip as you fit it, or it will gradually shrink back and leave a gap at the ends.
