FUEL ADDITIVES?
AndersLS
Post Thu Oct 19, 2006 9:00 am
Hello forum....do fuel additives actually help? "Pour this magic in your tank, and your car will go like crazy"?????
GDBN
Post Thu Oct 19, 2006 9:03 am
Hej Anders ... har du virkelig brug for et svar pÃÂ¥ det ??
G
thebigone
Post Thu Oct 19, 2006 9:16 am
go on then one more time so we can all reads it 8O
thebigone
Post Thu Oct 19, 2006 9:20 am
mark_i
Post Thu Oct 19, 2006 10:06 am
Fuel additives...?!!! spend your hard earned on a decent set of tyres, or better still get the ECU and Motronics engine sensors working optimally.
GDBN
Post Thu Oct 19, 2006 2:56 pm
It was .... do you really need an answer to that.
Speaks for itself I hope !
E30Mark
Post Thu Oct 19, 2006 3:10 pm
The only one i have used that worked... was STP inlet valve cleaner on my old 323i. The car just was not running as sweet as she used to, a Mercedes mechanic recommended the stuff, so i tipped some in the tank, and after 100 miles the car was running so much smoother! used to repeat the process every 12 - 15K it really made a difference! It's damn hard to buy these days, comes in a bright yellow bottle.
Never tried anything else.
PM for details
iDreamBeemer
Post Thu Oct 19, 2006 3:13 pm
Redex is good for old injection engines, can help do a little internal cleaning for you which is always good, more a keep it as it is rather than making it better type thing though
if that makes sense!
benjy
Post Thu Oct 19, 2006 3:58 pm
I'd agree with idreambeemer, Every so often i chuck a bottle of redex in with a full tank. Seems to be a bit smoother after half the tank or so........or maybe thats just me!
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
shazE30
Post Fri Oct 20, 2006 12:06 am
in my experience depends on the condition of your engine if its really battered then treatment does help a little otherwise no signifficant diffrence
kam-325i
Post Fri Oct 20, 2006 4:23 pm
The only thing i have every used is 10Kboost......although not a "put in your petrol thingy", it helped to smooth out a rough idle......
