taking the numbers off the boot
jaywe30
hi, just need alittle help, are the numbers on the boot ie 325i stuck on or pined as i want to remove mine, please get bk to me, also anyone know the best way to do this cheers
d6dph
Stuck on with foam trim tape.
Warm slightly with hot water or hairdryer and they should come off. be gentle if the paint doesnt look too healthy.
cliffybabe
- Powered by Nelly
I used a hot kettle of water and a wire tie through the tape
mark_i
after warming up with the hairdryer or water, good quality dental floss helps to separate the numbers from the bootlid without snapping
d6dph
Yeah i used a thick bit of cotton with washing up liquid to act as a lubricant. worked a treat.
iDreamBeemer
good quality waxed dental floss, run behind the numbers and then some bug and tar remover will get any remaining bits.
