Is this the proper blackline steering wheel hub? proper fit
clydesdale
Post Fri Oct 13, 2006 2:08 pm
Image[/img]
I bought a used blackline and it came with a nardi hub, part number 0604. This 0604 has a 40mm collapsable portion with part number 11294, under the rubber accordian trim piece. My problem is that it puts the wheel closer to me than my stock wheel. This is on a 1987 325is. Also, I do not quite have the hang of posting pics on here. I will try to get the pic to be bigger instead of a thumbnail. THANKS
Lennerd320i
Post Fri Oct 13, 2006 3:58 pm
i guess it's normal when you're using that kind of wheels...
eko
Old timer
Post Fri Oct 13, 2006 6:48 pm
clydesdale,think it was you I was talking to on R3V?
As i said then,your hub is identical to the one on mine,same part numbers etc so id assume this is correct for E30`s!
Dominitry
Post Fri Oct 13, 2006 6:52 pm
Yes thats the right one.
clydesdale
Post Sat Oct 14, 2006 1:02 am
Yep Eko that was me. It definitely changes the stock configuration. I will likely get used to it, but at this time I prefer the location of the stock wheel. I have spoken to a company in Florida, USA and they acknowledge that Nardi hubs are a bit of a pain in the arse with that collapsable portion. I emailed him pics and dimensions and he is going to talk to his supplier to see if there is a more suitable hub. I dont understand why they needed to make the hub so damn large and push the wheel away from the lights and wipers.
