coolant hose advice(urgent)
delboy8000
Post Thu Oct 12, 2006 10:18 pm
hi all,my 325 exploded at a mcdonalds drive thru today(serves me right,i know).the hose going into the bulkhead had torn,steam everywhere,i switched engine off asap,problem is,ive cut the hose but cant reconnect and there's no way over getting ur hand in as i needs a really firm push/twist.any ideas? :cry:
kam-325i
Post Thu Oct 12, 2006 10:21 pm
When i did mine, i used a little veg oil to make it slip on a bit easier....
Ant
Retired Team Member
Retired Team Member
a new one is the obvious answer, but , to get you outa the shite, you could cut the hose further back under the intake, fit the remainder to the heater stubs, then add a small section of copper tube to bridge the gap
strictly a temp soloution though dude !, and make sure and bleed the system ASAP to avoid any long term damage.
HTH
delboy8000
Post Thu Oct 12, 2006 10:49 pm
cheers guys,i'll get a new one from the dealer,any ideas o cost?also,will it still be a tight fit? :mad:
Post Thu Oct 12, 2006 11:14 pm
This the hose that goes from the back of the head to the lower heater stub on the bulkhead?
To get better access to replace it, unscrew the plastic nuts that secure the wiring carrier across the back of the engine, and tie it up to the wiper shafts with string. The access panel into the under scuttle area can be removed as well if you still can't get enough access. Only four self tappers hold it in place.
delboy8000
Post Thu Oct 12, 2006 11:17 pm
Brianmoooore wrote:This the hose that goes from the back of the head to the lower heater stub on the bulkhead?
was attemting that brian but only noticed 2 screws. :o: ,yes it is the bottom stub,ill try tomorrow,thanks.
Post Thu Oct 12, 2006 11:24 pm
If the hose has gone at the head end (the usual place), then you won't get it on after you've cut the end off. The very end of the hose is considerably bigger than the rest of the hose.
delboy8000
Post Thu Oct 12, 2006 11:44 pm
Brianmoooore wrote:If the hose has gone at the head end (the usual place), then you won't get it on after you've cut the end off. The very end of the hose is considerably bigger than the rest of the hose.
very true brian,had to give up and get the bus!will a new one from dealer fit on straightforward?
Post Fri Oct 13, 2006 12:37 am
New one goes on easily enough. Put the hose on, tighten the clamp at the engine end, fill the coolant bottle way above normal level, then pull the hose off again at the bulkhead end so that all the air comes out, followed by a little coolant. Push the hose on and tighten the clamp.
Switch the heater to full hot and turn the fan on, then start the engine.
Monitor the air coming from the heater and watch the temperature gauge as the car warms up. If you have an airlock the air coming from the heater will remain cold, and the temp gauge will quickly go into the red.
Release any airlock by overfilling the coolant resevoir again and pulling off the upper hose on the bulkhead.
DRIFTBOY
Post Fri Oct 13, 2006 12:46 am
If a hose is tight going on, especially in a confined space, I find a small squirt of WD40 helps a lot!
