shaking in 2nd
JMRe30
Thu Oct 12, 2006 12:15 am
My car shakes when I let go off the gas particulary in 2nd gear. Any ideas on what might be causing it? I know the mid section of my exhaust is rusty to the point where i can hear it whistle, and the heatshield under my spark plugs has a hole in it. Could any of this be the cause?
JMRe30
Thu Oct 12, 2006 12:20 am
forgot to mention it's an 88 316i with injection m10 engine
JMRe30
Thu Oct 12, 2006 6:31 pm
bump. no one?
jcjdavis1
Thu Oct 12, 2006 6:42 pm
Hi Is it Kangaroo petrol if so I think if you do a search in the tech section you might find somthing to help.
tekila325
Thu Oct 12, 2006 6:47 pm
If you feel the shaking in lower gears more the others check the "Guibo" on the output shaft of the transmission, or maybe worn CV joints on semi-axes.
BMW
Once U have One U gotta love it.
Not a BMW but one more hoby: http://www.slavec-racing.net
gareth
Thu Oct 12, 2006 9:52 pm
i'd check the following:
- guibo coupling (propshaft to gearbox rubber donut) for any splits, cracks or missing / loose bolts
- propshaft centre bearing. a pain to see as it's hidden by the exhaust heatshield
- wheel bolts. loose ones can cause funny noises!
