Anyone know?
Andy
Do E36 springs fit a E30?
stuartgallafant
andyborris
OK, thanks
Andy
Andy
Demlotcrew
Only the E36 M3 srings fit.
Andrew
Andrew
stuartgallafant
gareth
interesting. this could yield the higher spring rate i want for the front of my M30 tourer. do you have any more info or know any relevant links andrew?Demlotcrew wrote:Only the E36 M3 srings fit.
andyborris
Phoned Eibach and gained this:
E36 M3 (not Evo) struts use the same front spring as a E30 and the springs that Eibach sell for this car (E36 M3), late (88-90) 325i and all years of Cabrios have the same front springs. The kits however have different part numbers.
The helpful young lady I spoke to also mentioned that Eibach plan to stop making springs for the E30 next year.
You can also order springs individually, as spare parts, though no warranty is given.
How Eibach springs relate to standard, in terms of height and ride, I've no idea!
Who's going to take a chance?
gareth
that's interesting... so the E36 doesn't have a higher spring rate even though it's heavier? that blows my idea ouf of the window then!
andyborris
I think your idea was the same as mine, to compensate for the heavier M30 engine?gareth wrote:that's interesting... so the E36 doesn't have a higher spring rate even though it's heavier? that blows my idea ouf of the window then!
I think I may try a pair, the cars handling is frightening at speed at the moment!
gareth
correct! mine is also scary at all speeds! i suspect it's not helped by having the wrong springs ( i reckon it's got 4 pot saloon springs on!!! it's now veeeeery loooow with the M30 in!
