Anyone know how to remove the passenger side seat back? I can't seem to get it off as it is held in place by the tilt levers on either side, where as the driver's side only has one tilt lever so it's easy.
Is there something really easy I'm missing?
Cheers!
Recaro seats question!
Phatz
billgatese30
pull the plastic handle bit off, followed by the plastic surroiund thats clipped to the side of the seat, then you should be able to see a screw that holds the metal lever on to the mechanism, not sure but i think its the door side handle that is removable
Phatz
Oh right! I will have a look right now, thanks for your help mate.
Martin
Martin
