Can anyone outline the process for removing stone chips or key scratches from your paintwork ?
Details about what grade wet&dry to use would also be great.
Stone chip repair ?
smithy318i
c76jon
http://www.langka.com/chip-scratch-repa ... d44fa3747c
this is amazing stuff
used it for years and it works.renders stone chips almost invisible
tho your touch up paint needs to be spot on match
jon
jon
316eyes
It's available from here http://www.frost.co.uk/default.asp Full kit for Ԛ£15 and worth every penny.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
c76jon
they are out of stock at the mo
and thats just the bob eliminator iirc
jon
jon
316eyes
As always you are correct Jon.
Didn't realise there was a "fuller" kit till I looked at your link.
david106
Has anyone ordered the full kit directly from langka or can you buy the full kit in the uk?
smithy318i
Does this Langka stuff work on metallic paint?
snowman
Does langka work ok on lacquer painted or not.
