sorry i'm slightly tippsey ... and i'm not best
AUTO Box info
320iAN
today i set about cleaning the engine bay of my E30 project (i was bored!) and noticed that the accelerator cable was way toooo slack, so i tightened it up a few thread's
... then my mate thought "OH i'll tighten up this cable for the big man" ... to which i knew nothing about
till tonight i thought, think i'll take the 320 a spin ..... all was fine till ?? no gear change from the Auto box!! my mate told me later that he had a go at tightening a cable, to which he pointed at a cable which runs from the acc/ linkage to the gear box, i tried to slaken it of but it actualy feel's like it's came off at the gearbox end? is this posable ... would this effect the Auto box from changing gear??
at the best of times at describing fault's!
ed325i
I dont know if this will help you.
Distance between cable stop and end of cable sleeve at idle 0.50 +- 0.25 mm
With accelerator pedal in kick down position 44.0 mm (minimum)
320iAN
think it's gonna turn in to a summer car instead of a winter runner
ed325i
The box end is shown in the 1 st pic its the one in the middle. you have to loosen the nut. push the selector lever forwards (towards the engine), pull the selector cable rod back and tighten the nut.
320iAN
thanks again
320iAN
would i be right in thinking that with my mate tightening the cable then he has jammed on the "kick down" ? .... just gonna go out and slacken it back off and see what happens
ed325i
I dont know anything about autos I have only just got a 323 auto so I reading up on them.
I have got to change the filter in the box some time.
320iAN
nop!!ed325i wrote:Is it going now ?
i drove it (nursed it) to my local tyre fitters and put it on there ramp, the cable goes in to the box
drove it home and stuck it in the corner
320iAN
HELP!!
can anyone tell me if the Kick down cable has jammed can this stop my E30 changing gear?
drives spot on except it wont change up the box?, but if i boot it then when the rev's hit red it changes up a gear!! also does anyone know how i can get at the gearbox end of the cable? do i have to remove the sump to adjust/fix the cable "HAYNES MANUAL IS CRAP!"
any info at all will be of great help
320iAN
anyone?? please, can anyone help with this??
ive removed the sump (well it's hanging by the dip stick pipe!!) the cable is not connected that i can see, but i can't figure out what it's meant to be attached to? i can't see anything that should hold the "hammer" on the end of the cable??
Ant
- Retired Team Member
post a pic up dude, we'll get it sorted in the end, somehow.
Email FTW
320iAN
it's fine... kinda
the part the hammer slot's in to had spun round (out of site) but after 2hrs of lying in the rain under a car that's only sitting on 6" lump's of wood under each wheel
i decided F--- it!! and i went to ASDA for a carry oot
it's thee most fiddly thing ive ever tried to sort, i think converting it to a manual would be a quicker job!
hopefully it'll be dry tomorrow
CHEERS
CHEERS
320iAN
40 min's is all it took this morning to get the cable re-seated
all back together and it's driving smoother than it was, gear change is all working and the kick down is kicking in when needed
thank's all very much for the helpfull info .....
i even found some time to start buffing the paint work and i must say it's looking rather shiney
ed325i
Good you got it sorted out
Now you have just got to keep your mate away from it
320iAN
ed325i wrote:Good you got it sorted outNow you have just got to keep your mate away from it
