rear head rests
adil325i
Wed Oct 04, 2006 7:53 pm
Hello,
Does anyone know the part numbers for the rear headrest fitting kit from BMW? I have ran a search, but havent found anything.
Cheers guys,
adil
dark_sounds
Wed Oct 04, 2006 8:20 pm
i have a rear headrest fitting kit
im in croydon too ;)
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
adil325i
Wed Oct 04, 2006 8:23 pm
Hello there,
How much will you let the kit go for?
Cheers,
Adil
dark_sounds
Wed Oct 04, 2006 8:30 pm
20Ԛ£ dude :)
adil325i
Wed Oct 04, 2006 8:46 pm
Hello again,
Ill have the kit from you. What does it include exactly?
Also, whereabouts in Croydon are you based?
All the Best,
Adil
dark_sounds
Wed Oct 04, 2006 9:02 pm
hi adil,
im in shirley, kit includes the brackets, runners, plugs, have i missed out anything??
is beige leather any good to you ? i got beigbe leather head rests and a biege leather rear bench as well...
adil325i
Thu Oct 05, 2006 12:01 am
Hello,
I have a grey leather interior, so beige has no use for me im afraid - thank you for the offer.
Im based in South Croydon, between the bus garage and Jaguar dealership.
May come and collect this weekend if possible?
Cheers,
Adil
dark_sounds
Thu Oct 05, 2006 12:04 am
yeah dude, my number: 07746448540 let me know when you want to come along and collect, any time sunday is best :)
adil325i
Thu Oct 05, 2006 5:35 am
Hello there,
Sunday is fine. I will be sure to call you then.
Kind Regards,
adil
Thu Oct 05, 2006 9:29 am
Presume your car is a saloon, not a touring?
dark_sounds
Thu Oct 05, 2006 9:45 am
mine is, yours??
adil325i
Thu Oct 05, 2006 10:52 am
Hello,
Ill be retrofitting these into an e30 m3, if not a 325i coupe. Are there any issues that I have overlooked?
Regards,
Adil
Chris-W
Thu Oct 05, 2006 10:55 am
No, it's just you don't need the lit if you have a touring - they are all 'rear headrest ready'.
Thu Oct 05, 2006 8:14 pm
Tourings don't all come with fittings for rear headrests in place, but the fitting kit required is different from that used on saloons.
Rear headrest kit for a touring is identical to that used on all E30 front seats, so you can get the bits from any threadbare old front seat on a scrapper.
Chris-W
Thu Oct 05, 2006 8:37 pm
You just need the plastic inserts & caps.
Thu Oct 05, 2006 9:00 pm
Chris-W wrote:You just need the plastic inserts & caps.
And a pair of headrests!
Chris-W
Thu Oct 05, 2006 10:09 pm
And hands to put them in, but I'm sure you'll come up with something else Ive missed.
Thu Oct 05, 2006 10:30 pm
Plasters for your hands, for when that clip at the bottom of the backrests gets you as you pull them off!
SPADGE
Thu Oct 05, 2006 10:44 pm
Brian and Chris
When fitting rear headrests to the rear seats of a touring do you have to take the rear seats appart to get into the back of them or do you just measure where the holes should be and then put the clips etc in from above?
Cheers Spadge..
stuartgallafant
Thu Oct 05, 2006 11:05 pm
adil, why dont you just come to a poxie meet with us, and you can get the headrest off Ali there!!! come on adil, you know you wanna join the massive!!!!
Morat
Thu Oct 05, 2006 11:09 pm
Are the rear headrests the same as the front ones?
dark_sounds
too right, good point, adil, join the croydon massive!
might involve a bit of a test though,, involves neal with lubricant and violation,, but well worth it winkeye
Gortour
Thu Oct 05, 2006 11:14 pm
There's a Tech artcicle on the Zone telling you all you need to know about fitting rear headrests on a Touring. Try this... http://www.e30zone.net/modules.php?name ... adrest.htm
SPADGE
Thu Oct 05, 2006 11:52 pm
gortour wrote:There's a Tech artcicle on the Zone telling you all you need to know about fitting rear headrests on a Touring. Try this... http://www.e30zone.net/modules.php?name ... adrest.htm
Spot-on mate cheers :clap:
adil325i
Fri Oct 06, 2006 12:38 am
Hello Stuart,
One day mate. I got your missed call on the last meet, but couldnt really come - managed to have an accident in the m3. But once its all up and running, ill be sure to be meeting up with you guys.
Hope you're keeping well in any case,
adil
Chris-W
Fri Oct 06, 2006 7:30 am
What an excellent guide. Easy to forget that stuff's there sometimes!
Fri Oct 06, 2006 9:12 am
The guide goes through it all very comprehensively, but I'll add two things;
When pulling off rhe seat backs, the ends of your fingers are quite likely to make contact with a sharp metal edge hidden under there. Great care needed.
The parts bought from the dealer can all be got from the same scrapper that the headrests come from.
stuartgallafant
Fri Oct 06, 2006 1:35 pm
dark_sounds wrote:too right, good point, adil, join the croydon massive!
:lol:
well done Ali, thats just scared him right off!! he's supposed to learn about initiation on the night he arrives, not before!!!
Adil, im very well my friend, i hope you are good too? what happened in your accident? i hope you're ok fella. give me a call sometime mate...
adil325i
Fri Oct 06, 2006 2:29 pm
Hello Stuart,
When we do finally meet up, i dont think i will be leaving the confines of my car. probably just drive past with the window down or something.
Managed to hit a raised manhole cover in kingston - sump was fine, but the cover made contact with my exhaust - pulled the manifold from the block... left me with 6 broken studs in the block!!! Its an engine out job, so may take some time.
Just getting it back together again now, and whilst im at it, giving the engine a once over.
Good to hear youre in good health,
All the Best,
adil
Project_E30
Fri Oct 06, 2006 2:38 pm
Can you claim against the council?
adil325i
Fri Oct 06, 2006 3:29 pm
Hi there,
I have tried, but they keep forwarding me to the contractors. Dont really want to deal with them. However, may give them a fright with a solicitors letter.
cheers
adil
Fri Oct 06, 2006 7:54 pm
I'm no lawyer, but I would have thought your claim is against the council, as the owners of the road. It's up to them to claim from their contractors in turn.
adil325i
Sat Oct 07, 2006 5:50 am
Bearing in mind, there were roadworks, hence the raised manhole. However, I may have to seek legal advice - has anyone else experienced such a thing?
Cheers,
adil
Gortour
Sat Oct 07, 2006 9:57 am
May end up being the contractor at fault at this rate then mate. Sorry to be the bearer of bad news, but if they were working on the road and had the cover up, surely the tossers should have had the area fenced off... Health and Safety issue here methinks...? But would agree that the Council should be ultimately responsible as they OWN the road and the contractors were working for THEM...
adil325i
Sat Oct 07, 2006 11:40 pm
That does make sense. I think the best way to go is to consult a solicitor - but once again I am new on this front, so are there certain solicitors who deal with this sort of thing? I should really draft a letter with all the evidence, and present my case to them personally, then follow up with the solicitor... just dont want to complicate matters if it reaches that stage.
Thanks for the opinions guys,
Adil
