M-Tec suspension conversion
Ade
Post Mon Mar 28, 2005 9:38 am
What parts off the original donor do you need to do this?
Am I correct to think that any 318iS or 325 Sport will have the -15mm lower M-Tec susp. setup? 8)
cheers
Ade
Toby_Unna
Boost Junkie
Post Mon Mar 28, 2005 7:08 pm
i bought my setup for my 316i from a 318iS. i think the iS is the standard mtech suspension, it certainly lowered my car a fair bit.
you want the complete front struts (spring, rusty strut housing and damper which is inside the housing; they come off as one unit including the wheelhub etc), rear dampers and rear springs, and depending on what model your own car is, you may also want the front and rear anti roll bars.
Ade
Post Sun Apr 03, 2005 9:54 am
so should the 318iS and 325Sport struts have an outside diameter of 51mm?
where abouts is this measured? or doesnt it matter?
ade
