hi i have a 325i which hasa really bad flat spot when accelerating away from stand still also when starting its very slow at fireing up any ideas please
simon
flat spot
air flow meter probably, air leaks on the intake as well, split old rubber pipes
simondavies
thanks for that mate will check that out in the week
simon
simon
appletree
might be split hoses or a rubber blank on the throttle body ( the blank might be IS only but thats what my problem was)
Any chance you could re-size your avatar to
