here you go Dan
Im pretty sure he did. Its the only way the servo and plenum will fit together in the engine bay. Its how I did mine.bmw13fr wrote: have you cut the plenum to put the servo ?
hi,yes i had to cut a small amount out.About 2 inches long ,by 1 inch wide.I also fitted a vw golf servo which is smaller,and i still had to move the whole lot over on the bulkhead by half an inch.I suppose i could have cut more out of the plenum chamber but i was minimising the amount needed to be cut out.bmw13fr wrote:hi,
thxxx
Yep, il a utilisé un mastervac + support et commande de 540i E34. J'en ai àvendre si tu veux.bmw13fr wrote:ok, thank you
I saw a swap where the guy did not cut out the plenum chamber
he moved the servo in front of the car
They were just cut out of a stainless steel machine panel and ,the bonnet cut and then vents welded into place.The one on the exhaust side kicks out a lot of heat,the one on the other side is a bit of a pain in the arse and i had to cover the back of it with a piece af aluminuim plate to stop rain water getting on the air filter.e30-323ti wrote:Hi Andy,
Conversion looks great.
1 Question, how did you do those bonnet vents??
My engine bay gets a bit toasty with a couple of turbos crammed in there!!
I have replied to your PMe30s50b32 wrote:Excellent work!!
I am currently putting a S50B32 with a euro six speed in a US E30 M3 and need some help. I was wondering if you guys help me out?
1. I don't have the complete EWS system. I am missing the key, the antenna box and another EWS box. Can I bypass the EWS system? Can I use a any US e36 key/antenna box/two EWS boxes (all from same doner) with the euro ECU? Does anyone know a good junk yard in UK?
2. Is the iX brake booster and e34 m5 25mm mc better than 320 booster and e30 m3 mc if I was to use big brakes? Would all these require to cut the intake manifold?
3. Anyone dyno the differance between a single 3" exhaust vs dual 2"? What muffler did you guys use?
4. Did you guys use the Treehouse ECU plug? Is there another?
5. How did you get away from notching the subframe and bending the sway bar? What motor mounts did you guys use to allow the exhaust manifold to clear? I know some of you used costum manifolds but I like to keep the stock manifold in that I hear itâ┚¬Ã¢”ž¢s the best flowing.?
Thanks for the help
Art
So did I. Have you checked your email ?jmc330i wrote:I have replied to your PMe30s50b32 wrote:Excellent work!!
Thanks for the help
Art
