Yes, the Zone reduces the pics to fit the screen. Dont bother uploading higher res pics, they will be reduced as well.RCWells wrote:Is this everyone? Should I upload them in high res then?
Yeah, r3v leaves the pics the original size, but you get the scroll bar at the bottom - this screws the page up on the Zone, so the pic is reduced.RCWells wrote:For comparison: http://www.r3vlimited.com/board/showthread.php?t=75559
I used the same size pics on both sites, but you see the difference in size?
from his local shopRazza wrote:SUITE!
where did you get the plates bro?
I never have used Zaino. Usually use P21S, but was out so I used Wolfgang products this time around, and I don't think it's ever looked better.billgatese30 wrote:looking as good as ever
are you still using Zaino?
SaarbruckenLennerd320i wrote:wich region in germany is SB?
nice car mate!
No, unfortunately, it's not an option.wiledw wrote:Does right click, view image and then zoom not display the image at original size?
Yes, Alpina "replicas" aka, Kopis available here: http://www.abrahamsmotorsport.com/ , as well as other places. Size: 17x7.5" and I'm running Goodyear F1s in 215/40-17. You might know that the Alpina reps available in the UK are slightly different in design than the ones I have. The UK versions have a flat rim surface, mine are smooth/rounded.als87e30 wrote:alpina wheels? If so, sizes please
