whine/Whir from rear of 325 Cab E30
petrolhead63
Fri Sep 29, 2006 9:37 am
Hi, since I bought my E30 325 Cab it has had a strange whine in the rear, I have not properly investigated yet and hoped some experience feedback might save me time. normally I would suspect the Diff, BUT it is not quite a usual diff whine and it does not stop when you lift off the accelerator as a diff normally does.
Difficult to describe without being present but it is more of a whirr than a whine, it is speed related and continues if clutch depressed and coasting. Also it can faintly be heard almost until the car has stopped, again a diff normally needs a bit more speed. It is not particularly loud and I am struggling to make out if it is in the centre or too one side.
There is no noticable backlash in any joints, no knocks on drive take up etc. Any suggestions as to the cause welcome based on experience of the model. I did wonder if it could be a bearing on one of the diff. shaft outputs? Any common problems known out there??
chu346
Fri Sep 29, 2006 8:21 pm
It could be something like one of the wheels catching on the arch or something along those lines?
fuzzy
He who sleeps with "Gingers"
Fri Sep 29, 2006 8:31 pm
have you checked the wheel bearings?
Fri Sep 29, 2006 8:57 pm
Centre prop bearing maybe
Theo
Fri Sep 29, 2006 8:59 pm
Is it a rusty shed? A turd that I dismantled made a funny noise from the rear end, and I was concerned it was the LSD, but as it turns out it was just the HUGE holes in the inner arches which made the road noise much more noticeable!
Ben1984
Fri Sep 29, 2006 9:06 pm
I had a noise liek this in my old 320, turned out to be a wheel bearing
petrolhead63
Fri Sep 29, 2006 9:53 pm
guys the ideas are great, keep em coming.
In turn.
1)checked for rubbing...certainly not on arch, standard height car. Thought could be a mudflap so took em off! still does it, he he
2)Centre Prop......good idea, I am going to guess not. Think noise is too far back.
3) Rust holes! nope it is a goody.
4) Wheel bearing.......well have wondered and two of you think maybe too. I think, just think it may not be central, in which case it could be. I think that is what we will check. I need my usual nutty mate to lay on the back with seat out as I drive around....haha, did it with aimilar noise on an XJS and sorted it a long while ago.
Thanks all of you, I have learnt talk to the marque enthusiasts, usually people will know a models weak poits and likely/common faults.
Cheer
Petrolhead
Gouki
Fri Sep 29, 2006 10:11 pm
sounds like a bearing too me.
essexboy
Fri Sep 29, 2006 10:21 pm
sounds like a bearing to me had one go on my previous e30 n tht was more like a whiiring noise
DRIFTBOY
Fri Sep 29, 2006 10:30 pm
XJS!
What a wagon! Always loved those.
Especially after I passengered in a Lister 6.0 litre jobee!
Sounds like wheel bearing to me too though.
Or diff! But they go on forever like it.
When I bought my 325i the diff made it sound like a jet plane taking off!
mrLEE30
Sat Sep 30, 2006 6:01 am
drove one of them, silly car!
petrolhead63
Mon Oct 02, 2006 10:49 am
[quote="DRIFTBOY"]XJS!
Rust like poo, but great cars. I have had a cuple of 3.6 manual box cars, last one a Cabriotet, manual, with nicely firmed up suspension on Spax etc. Super car, but an E30 is far far better.
Ziggy
Mon Oct 02, 2006 11:37 am
More of a high pitched, 'hissy whine' than you'd expect from a wheel bearing? Diff input shaft bearing's where my money'd be.
http://www.e30zone.net/modules.php?name ... ic&t=46286 :cry:
If you've not got an LSD, at least it's cheap to get a new (2nd hand) diff, or a good oportunity to upgrade...
petrolhead63
Mon Oct 02, 2006 3:37 pm
diff input shaft bearing, yeah it could be. Hissy whine sums it up. My experience of wheel bearing on other cars is more of a screech or "singing to you" type of noise. I assume bearing and seal can not be done without major surgery?
romario
Mon Oct 02, 2006 7:58 pm
I had a noisy rear wheel bearing on my E36. Made a steady noise in a straight line, a low noise when cornering hard to one side and loud noise when cornering hard to the other. (because the problem was on one side.) Had to find a garage with a "press" to fit the new bearing.
Globulator
Tue Oct 03, 2006 11:58 am
romario wrote: Had to find a garage with a "press" to fit the new bearing.
That's a superb looking motor in your avatar. Oh Yes!! 8)
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Bailey
Tue Oct 03, 2006 5:50 pm
i've also got a bit of a dodgy noise from my cars back end.... i took it to the garage and they checked to see if the covers which go around the disks were rubbin... just a thought.... oh, and it wasnt that on my car if you were wondering...
Cheers, Guy.
petrolhead63
Tue Oct 03, 2006 9:22 pm
nope, checked all forms of possible rubbing. Its def mechanical of some kind. If it ever stops raining I might get under it jacked up and have a listen :?
