but every now and again ill press the alarm and the doors will stay locked. when it does this it wont unlock anything at all. so ill get in with the key. when i get to where im going i will arm the alarm and the door will probably stay unlocked so ill use the key again. but some random time later it will spring back into life and lock and unlock everything again.
it buzzes a bit when i press my alarm button like its trying to do something. but ive had it before where it doesnt do anything at all, no noise!
1st time this happend i took it out the wing (module thingy) pulled it all apart poked around a bit, got bored and put it all back and it worked. so next time it broke i cleaned EVERYTHING, all the contacts etc etc but it didnt do the job. so i left it and it decided to work on its own again.
im completely puzzled. im hoping its the module but i dont know what the symptoms should be if thats the case.
ALso i took it apart before and manually activated the relays with my pokey finger. this activated the lock/unlock system once but not the next time it happend. Grrr
im looking up to brian mooore i think? any help is much appreciated... firemen glad ive run out of matches lol
