severe pull to left
Bob_S
Post Wed Sep 27, 2006 5:35 pm
Right, I need to sort this. every now and then the 316i I look after seems to pull to the left quite severely, I've just renewed the front shocks and the tracking was set fine. and it was all good but it's come back so what could be the cause this time?
Bollocks to this 24v scrap!
Chris-W
Post Wed Sep 27, 2006 6:14 pm
On the brakes, or just randomly?
Gouki
Post Wed Sep 27, 2006 6:17 pm
is there play in the steering? does it happen when your going fast, pulling off at a certain speed?
MikeeMiracle
Post Wed Sep 27, 2006 11:04 pm
The rubber is another factor to consider. Tyre's with a stiifer sidewall tend to tramline more than other tyres. Next time it happens have a look at the road surface to see if one wheel is on a different surface...ie the road had been dug up to lay some cabling and you have one wheel on a different tarmac to the other.
Red 318is
Take me to the land of the twisty's :)
Bob_S
Post Thu Sep 28, 2006 5:37 pm
constant.. and quite severe. I've not had a good look at it yet might be a bush might be a fucked rack I dont know was just after suggestions tbh cheers lads
alan325i
Post Thu Sep 28, 2006 6:57 pm
Check to see if the caliper is also working correctly
