3:73 lsd
TW166Y
Post Mon Sep 25, 2006 4:49 pm
3:73 lsd, will this work ok with an m30 conversion. Not really clued up about diff's so any info would be magic. thanks fella's :wink:
Saying goodbye to 4-pot wrongness
Andy335Touring
Post Mon Sep 25, 2006 5:01 pm
You need a 3.64 or a 3.46, you might find first is too short with a 3.73, i've got a 3.64 but i want to swap for 3.46 because it's a bit short geared for me.
The above assumes E32/34 gear box and you have tyres that maintain stock rolling radius
Chris-W
Post Mon Sep 25, 2006 5:44 pm
I have a Z3 3.45 LSD if it's of interest.
Cheers,
Chris
Andy335Touring
Post Mon Sep 25, 2006 5:47 pm
What sort of dosh are you after ?
Sorry i've got to ask but is it in good nick/no whines/etc ?
Demlotcrew
Post Mon Sep 25, 2006 5:48 pm
A Z3 with a LSD?
The only Z car that came with real LSD's were the Z///M ones.
Andrew
Andy335Touring
Post Mon Sep 25, 2006 5:50 pm
Demlotcrew wrote:A Z3 with a LSD?
Andrew
Talking of 3.46's did you ask your mate ?
Chris-W
Post Mon Sep 25, 2006 5:54 pm
Andrew
I've touched it and it didn't disappear, so had thought it was real...
e30_Turbo
Boost Junkie
Post Mon Sep 25, 2006 7:00 pm
Andrew
I'm pretty sure the Z3 2.8i got an LSD too.
Mark.
Demlotcrew
Post Mon Sep 25, 2006 7:37 pm
The only Z car to have a clutch type LSD was the ///M coupe and ///M roadster.
The others had a trosen based LSD which is really no good.
HTH
Andy ill let you know.
Andrew
e30_Turbo
Boost Junkie
Post Mon Sep 25, 2006 7:44 pm
Demlotcrew wrote:The only Z car to have a clutch type LSD was the ///M coupe and ///M roadster.
But now you're changing the goal posts :roll:
TW166Y
Post Mon Sep 25, 2006 11:38 pm
Andy335Touring wrote:You need a 3.64 or a 3.46, you might find first is too short with a 3.73, i've got a 3.64 but i want to swap for 3.46 because it's a bit short geared for me.
thanks andy :wink: i take it, its no good then :cry:
Andy335Touring
Post Mon Sep 25, 2006 11:43 pm
If you have a little bit of time to shop around give it a miss
TW166Y
Post Mon Sep 25, 2006 11:46 pm
ok thanks andy, im currently trying to source a 3.64 or 3.46 :D
