I got a set of jamex shocks. Are they the same for both size of legs? The ones I got (s[posedly for a 325 leg, don't fit in the leg properly. They're a bit lose (about 10mm too small I guess and a little bit shorter then normal.
ALSO, the shocks, though both new, compress and extend and different rates. Is this normal? (Im guessing not).
Anybody shed some light on this?
Jamex shocks
SGP
There are two diamaters available,you must have the larger m tec suspension, standard on the is.sounds like you were supplied with the smaller stock.I think it's 45mm verses 51mm,the shocks should feel the same,they should be stored vertically,maybe they weren't?
If it ain't broke..
Fix it till it is
Fix it till it is
oze30
hmm.. I do have the larger legs (touring) but the guy I bought them from said they were for 325! I can't use them can I?
M5pilot
not unless you can get the Bilstein type reducers.
oze30
how much are they worth?
oze30
Are the collars bronze ish looking and have 2 slots instead of holes? If so, I have them already, but they're still lose in the legs
