can anyone tell me what is the biggest bhp expected from a 325 engine?i`m looking to spend a lot of money on my 325 this year but i`d like to know what sort of figures to expext.
the car is already chiped,stainless exhaust and KnN filtrer
so its not shy buy any standards,i just want to go that little bit further
can anyone help many thanks milly
biggest bhp from a 325
if it aint broke then try harder
bottlecapE30
there are a few guys running turbos that run over 400hp. It won't be much more then 200hp unless you go with forced induction.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
I am getting 192 with BBTB, Piper filter 6 branch manifold scorpion bbox but with a cat (to be replaced ) and oz (oguz3001) made 202 with an earlier car (higher comopresion ) and no cat..
http://www.e30zone.net/modules.php?name ... sc&start=0
mats 2.7 made 190.3 bhp@5425rpm and 217.7 Lbs unmdified...
I am putting a supercharger on over the winter....hope to get 270
Think PPF have just extracted over 700bhp from an M20 using the diesel crank to give a 2.7 plus some decent management, big intercooler, giant turbo and a trick inlet manifold......and then there's the rods, pistons and cams.
If you've got a lot to spend, you can make silly power
e30bmlover
- Ac Schnitzer prophet
s50b32 now your talking!
here we go!
i would get a cam, 6 branch, head work, 3 or 5 angle valve, big bore throttle body and a good re map.
it will rev it's tits off, you will lose some bottom end torque but it will fly for a 325i after 3500rpm and make a "proper" 190bhp or there abouts. That would keep me smiling for a while!
that lot will cost u a good dollop to get done aswell
