timing belt issues
blingsta
Boost Junkie
Post Sat Sep 23, 2006 6:17 pm
hey guys.. ive put same post on tech help 2....
having got myself a 3mm decomp plate, ive put head back on, but bloody timing belt wont go on for love nor money... ive undone tensioner all the way but still no joy?? any help will be appreciated.. cheers
Turbo-Brown
Boost Junkie
Post Sat Sep 23, 2006 9:29 pm
3mm?! christ on a bike!
What sort of CR are you expecting with that dude?
Perhaps try going to your friendly local machine shop or autofactor and trawling through their catalogues for belts that are 1 tooth longer or something?
maxfield
Post Sat Sep 23, 2006 9:31 pm
The comp was 10:2:1 I think before the decomp plate was there i believe.
blingsta
Boost Junkie
Post Sat Sep 23, 2006 10:11 pm
spot on Maxfield, it should drop to 8;1 with plate on there.. Have been speaking to Ant who has advised me to take off tensioner completely and try that way.. suppose the head not being torqued down soesnt help too, but im still waiting on delivery of my non stretch bolts.. well 2moro is new day, hopefully with some luck on my side.... we'll see how it goes???
Turbo-Brown
Boost Junkie
Post Sat Sep 23, 2006 10:25 pm
Think if it's not fitting now, it's unlikely to fit when the head gasket's been squidged down by a couple of tenths of a mm, unless it's just marginal that is.
Hope it works out for you though dude, how'd you end up with a 10.2:1 CR though? :mad:
blingsta
Boost Junkie
Post Sun Sep 24, 2006 12:15 pm
by using eta bottom end and 325 head !! ive been told the belts have 127 teeth, but they also do 128 teeth belts, you reckon that maywork??
Turbo-Brown
Boost Junkie
Post Sun Sep 24, 2006 1:23 pm
gotta be worth a try! :)
chu346
Post Sun Sep 24, 2006 6:46 pm
blingsta wrote:by using eta bottom end and 325 head !!
are you sure that is correct? mine is using a 320i head which gives a c/r of 10.2 so I should think yours would have been lower than that. Was it an early v.high comp block or the later high comp block?
I got the later block which if I put a 325i head on would give me about 9.4 c/r.
blingsta wrote:ive been told the belts have 127 teeth, but they also do 128 teeth belts, you reckon that maywork??
The Eta's have a slightly taller block, so maybe it's the Eta belt that is longer?
blingsta
Boost Junkie
Post Sun Sep 24, 2006 10:37 pm
Hmmmm, not really sure which block was used for the coversion, im also now thinking about using a vernier pully, i believe there adjustable!! cars are nuffin but headaches!!
blingsta
Boost Junkie
Post Mon Sep 25, 2006 10:26 pm
i tried again today this time with the spring off the tensioner... belt still wont go on.... im gonna try a longer belt, can i try one from any make car or is there certain belts that wont fit??? any advice guys?
Turbo-Brown
Boost Junkie
Post Mon Sep 25, 2006 10:33 pm
You tried the 128 tooth one yet mate?
Reckon that'd be the best place to start if not :)
blingsta
Boost Junkie
Post Mon Sep 25, 2006 10:56 pm
naah i havent tried that yet... does anyone know which bimmas these belts come from??
