Wasted Spark Installed
Andy335Touring
Post Mon Sep 18, 2006 9:31 pm
I've not long forked out for a set of bosch but i'll bare it in mind when they need changing mate :thumb:
Are you going to the pod meet ?
Demlotcrew
I sure am buddy
Andrew
Andy335Touring
Post Mon Sep 18, 2006 9:33 pm
nice one dude :cool:
Demlotcrew
Post Mon Sep 18, 2006 9:34 pm
Thing is with the Denso Iridum plugs they dont last very long :o:
Turbo-Brown
Boost Junkie
Post Mon Sep 18, 2006 10:33 pm
Think I've got 0.9 or something on mine Andy :)
Andy335Touring
Post Thu Sep 21, 2006 9:32 pm
Well finally got it sorted, swapped all the wiring around and the fecking thing wouldn't run, well it did run very poorly, popping and banging. I pissed about trying to get it to work and it made me 3/4 hrs late for work :x but luckily the supervizor was on D/O and the manager was out at a meeting so i got off scott free ! :D
Sent an email to Emerald for some help and they sent me a soft ware update which did the trick.
....mmmm.....i seem to be missing some thing :)
gcorky
Boost Junkie
Post Thu Sep 21, 2006 10:04 pm
Ant wrote:Yeah, certainly all MS kits will now be built with the provision for wasted, Blingsta's cab is equipped with the exact same ECU and loom as mine, however the two " spare" coil drivers are software disabled for now.
Seems to be advisable to future proof the setups as I go, can be added retrospectivly to all existing MS V3.0 ECU's too, so bonus there :cool:
If I could get numbers for an MS group buy, and get confirmed orede with deposits, we could all save a few Ԛ£Ã”šÃ‚£.
Morat, the only parts left are the coil +'ive feed, the coolant temp wiring and thats about it, the rest of the motronic is still in place, but all dormant, this way the engine bay looms stays stock to look @ :twisted:
is mine just software disabled or is it missing the required hardware to run ws?
525 sport
Ant
Retired Team Member
Retired Team Member
Post Thu Sep 21, 2006 10:10 pm
you need two more VB921 coil drivers , duplicate the circuit from the D14 as you have now, x2 and then enable spark output B and C in the settings menu on MT G man.
:thumb:
edit: Well done Andy !
gcorky
Boost Junkie
Post Thu Sep 21, 2006 10:21 pm
Ant wrote:you need two more VB921 coil drivers , duplicate the circuit from the D14 as you have now, x2 and then enable spark output B and C in the settings menu on MT G man.
:thumb:
hmn ok then ,d14?vb921 coil drivers-easy fella-translation?lol
525 sport
gcorky
Boost Junkie
Post Thu Sep 21, 2006 10:31 pm
525 sport
e30_Turbo
Boost Junkie
Post Fri Sep 22, 2006 9:19 am
I got my coil pack through yesterday! and plug with some wires!!!
Now time for V3, wasted spark and drop kicking my dizzy cap over the fence!!
e30bb
Post Sat Sep 23, 2006 10:26 am
Ant wrote:Coilpack is triggered from the std 60-2 wheel and VR sensor Andy, this MS has triple coil drivers internally to run the pack, no external EDIS module is being used.
Hi, ant,
Question: if i decide to use the EDIS module can I use the std 60-2 and VR sensor with coil pack?
And put my name down for the megasquirt group thingy, defo in!
