Ԛ£88.00 a bit exessive !!!!
ht leads
chippys323
hi all, what is it with the cost of ht leads.
e30bemer
- Nutters
depends on where u go!!
but you can only assume u get what u pay for!
I assume that its a 6 pot, so that sounds ok!
Any one else agree??
Ant
- Retired Team Member
not a bad price, why are you changing them though, they last 4 ever dude !
my lach touring still has the originals as far as I can tell ( FSH 226K ) and they are 100% spot on for resistance and condition still.
Email FTW
fowler
- Boost Junkie
shame the car aint ant
EX A-Tech Workshop bitch !!!
gone but not forgotten
Chris-W
JazzMan
I got some 8mm Magnacore ones as they're about the same as stock and should in theory be better
toby
Chris-W wrote:
My wife said she could see my skeleton flashing on and off.
Er.. no I mean sympathies...
The newer cars can do you some really nasty damage or even kill with their high voltage stuff.
Does anyone have any horror stories?
Cabrio
Hi
AutomacGB sell Magnecor leads for that sort of money...will check prices but they are better than the originals
Chris-W
toby
Yeeaah what a buzzChris-W wrote:Odd thing is I, once I had managed to let go of the lead, actually felt great!
Andy335Touring
DemonDaz
The wifes Metro had loads of problems, but in the end it was running but lumpy. A couple of garage trips didn't fix it so I had a look, started it up and went to pull out an HT lead and got an almighty shock up the arm. New leads and it ran a treat!
chippys323
hi .i dad to change then as the alternater et two of them
what a pain.
what a pain.
billgatese30
the last place i worked two lads decided to see who could hold out the longest holding on to an HT lead.................very amusing i must say, it was like the green mile when they execute the guy without wetting the spongeChris-W wrote:Odd thing is I, once I had managed to let go of the lead, actually felt great!
I've never come across a duff E30 ignition lead either, except for the odd one that has been physically damaged.
Don't waste your money on Magnacor or other fancy leads. Leave them for the people who need them - like Land Rover and Ford owners.
OE leads are every bit as good as Magnecor, so just get a second hand one or set, if you're convinced yours are dud.
Think you'll find there's a slight difference in quality between Rover and BMW OE parts!DemonDaz wrote:The wifes Metro had loads of problems, but in the end it was running but lumpy. A couple of garage trips didn't fix it so I had a look, started it up and went to pull out an HT lead and got an almighty shock up the arm. New leads and it ran a treat!
DemonDaz
He he, Obviously, Rover are MUCH better!!!!Think you'll find there's a slight difference in quality between Rover and BMW OE parts!
Cabrio
Brian
In all fairness I have tested Magnecor leads on several cars and they give a better spark and better performance and will last far longer than originals...also thicker and even a nice colour if want blue or red (race leads)
Downside as thicker difficult to fit in holders...
But also work better with Gas conversions, competition engines etc
Accept Behr leads (original) are excellent , but expensive to replace, but some cars are now old and leads can break down
Only other downside is magnecor cant get Behr plug ends foe the E30 M3 but they perform well
Dont want to get into a dispute but this is my opinion...accept yours may be different
I fully agree Magnecor leads are excellent - but so are OE BMW. BMW are not "several cars"
I know all about the ignition requirements of LPG cars - I've run a 325 touring on the stuff for several years - on 250,000 mile, 18 year old original ignition leads.
You're doing well if you can get a Land Rover to work on gas for three years without renewing the leads.
Cabrio
Brian
Agreed...I was just adding the the thread...if replacement is required then the Magnecor items offer a high quality option that is cheaper than the originals and Euros etc..
See you at a show sometime
