bazza93 wrote:hi guys !
just got back from tesco's, thought i would check the old girl over abit,
found that the exhaust manifold is blowing ( from the head ).
is this an easy repair as i have heard some stories about the studs, also are the gaskets readily available.
cheers
chris
Gaskets are available from BMW, ones from ECP are poor quality, GSF ones are similar if not the same as dealer ones.
I've done this job twice on 2 different cars of mine, and I was suprised how easy it was, all nuts came off easily, and a couple brought the stud out with them, not a problem!
It's when the studs snap the problems start.
Don't assume yours will be this easy, as I've read a few different experiences on here!
Order the new gaskets from BMW, and get some new studs and nuts while you're there.
