springs
player6
what would happen if i put 325i lowering springs on a 318i
scot 328i with 260bhp
Andy335Touring
It might sit a tad higher at the front ?
StuBeeDoo
If you look on ETK, there are only 2 part numbers listed for front springs on the 318iS. Both these part numbers appear in the lists for front springs on 320i and 325i.
318iS listing here: http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
320i listing here: http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
325i listine here: http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
I picked the same build month for all three examples.
HTH
Stuart
HTH
Stuart
StuBeeDoo
player6
thay are 8omm on the 325 so it mit only drop it by say 60mm
Andy335Touring
The thing you don't get with that online ETK is you also get differant springs fitted to the same model,like if the car's got air con then the fronts will be differant or if the cars fitted with a tow bar the rear's are differant.
My set up is a bit of a mix,it's got Spax adjustable Touring/saloon dampers front and rear with Spax M3 springs at the front and Spax Touring/saloon springs at the back.
I was going to use Spax M3 springs all round but the rear was to low for my liking,might be a better height now i've took my tow bar off ?
The ride height is a tad lower than in my sig pic because the car's not completely level(N/S is in the gutter).
