* Keeps blowing window motor fuses (30A). Previous owner did tell me but its not until I found his pile of spent fuses (about 20
He had an auto electrician check it all and apparantly the wiring is fine, he ended up putting in a remote fuse in the glovebox to get round the problem (or make it quicker to change anyway!)
* Intermittent wiper is crap! Goes up, stops vertical. Next pass it just jumps down 4". Next time 4". Next time it reaches bottom. Repeat
Was told this could be down to the wiper unit got water in and the terminals all rusted up?
Full wipe works fine, manual you have to hold down or it will stop wherever you let go!!
* Headlights adjust - this is just done on the white plastic things isnt it (which will undoubtably snap!)
Any tricks or is it just a case of hope for the best and plenty of wd40?
Think thats it
