Injectors?
Pal318is
Post Fri Sep 15, 2006 3:26 pm
Does anyone know how the injectors are taken out of the inlet on a m42 pls??
Got it all in bits at the moment, wanted to clean all the bits, make them nice and shiny, befroe i put the new lump in..
Pal
Pal
Image[img]http://Image
martinclan
Post Fri Sep 15, 2006 4:47 pm
As I remember you have to split the inlet manifold (it's in two halves bolted together) unbolt the fuel rail and the injectors should just come out. They are only held in by O rings and the fuel rail. (Also have to disconnect the wiring loom)
While you have them out it's worth having them cleaned and checked for flow by a specialist. I had mine done by the BMW specialist in Hitchin - quite close to you if you are in Bedford....
Robin
It's an E30 Jim but not as we know it...
Pal318is
Post Fri Sep 15, 2006 4:56 pm
martinclan wrote:As I remember you have to split the inlet manifold (it's in two halves bolted together) unbolt the fuel rail and the injectors should just come out. They are only held in by O rings and the fuel rail. (Also have to disconnect the wiring loom)
Robin
Nice one fella, i think i've been to the place in hitchin your on about..is it behind or near a petrol station.
The engine is sitting in my parents back garden at the moment! So everything is already disconnected...I took apart the inlet, both parts and the injectora are still in one of the bits of inlet, so it sounds like i just need to pull it?!
How much does it cost from that place in hitchin bud??
Thanks for the advice
Pal
Pal
martinclan
Post Fri Sep 15, 2006 5:23 pm
Yes - its behind the Shell garage on the Bedford road. I had 6 done (actually from my other car a 325) and I think it was about Ԛ£60 (cash...). For that they were cleaned checked on the flow rig and new ends and o rings fitted.
Robin
Pal318is
Post Fri Sep 15, 2006 6:10 pm
Cheers Buddy.
Pal
Pal
