central locking, door lock...
michael24m
Post Thu Sep 14, 2006 1:47 pm
hi guys
i'm trying to fit an aftermarket central locking sysem...i can atach it to the horizontal rod in the locking mechanism but the problem is, the locking mechanism's movement is very arduous...the central locking servos only power up to 3 kg....is there any way i can make the locking mechanism looser? making it easier to move? i have to take all the doors standard mechanism apart? help!
thanks!
smithy318i
Post Thu Sep 14, 2006 2:47 pm
are you fitting new servo units? I think it would be better to use the ones which are already installed.
michael24m
Post Thu Sep 14, 2006 3:03 pm
well i don;t have anbything installed, i'm installing the servos that come with the kit...:| improvisation improvisation improvisation...the problem is the door mechanism is pretty stuck bearly can close it with the key...it was pretty hard before but i just remove the bolt and put it back toghether from the locking mechanism rod assembly in the dor...
smithy318i
Post Thu Sep 14, 2006 3:12 pm
so your saying that your car doesn't have c/l ? (I thought it came as standard)
The best place to mount your servos would be in place of were the factory ones go. The c/l takes very little effort to lock/unlock from the factory servo.
the mounting point can be found below the lock mechanism on the inside of he door. It may also need a bit of WD40.
michael24m
Post Fri Sep 15, 2006 11:14 am
hmmm, tried to fiddle with it all day, cant atach it to the vertical rod....the original servos mounting point is 15 cm offside from the vertical rod trajectory...hmmm...i'm curious to see what kind of atachment the factory servos have to the locking mechanism....
robmpulse
Post Fri Sep 15, 2006 1:34 pm
if your car came with C/L to begin with, why not keep the factory servo's andjust trip them with a wire connection?
If it didn't, I don't know what to tell you then to start replacing stuff or maybe try using some graphite lube.....
Post Fri Sep 15, 2006 8:16 pm
Frankly, you would be better off putting your afterrmarket kit on ebay, and getting the proper E30 kit from a scrapyard or from a zoner. The kit will be ten times the quality and will fit perfectly.
michael24m
Post Fri Sep 15, 2006 11:32 pm
thanks, thought of it myself, i'm thinking of trading in the central locking kit that came with the alarm, for a better alarm only and fish for the central locking at the scrapers. eagle alarms any good? how about scorpion alarms?
