Prop Centre Mount and Bearing
m-dtech
Unapproved Trader caution
Post Thu Sep 14, 2006 10:25 pm
Ok do i need to remove the prop completley ? or can i just remove the front section ?
m
tommype30cab
Post Thu Sep 14, 2006 11:13 pm
ur gonna have to remove the whole lot mate im afraid. 17mm spanner for the nuts and a mate on the brakes always helps crack them off. If ur changing ur prop bearing housing make sure youve got the rite one cos there is a difference in the distance between the bolt holes. (14cm centre to centre on early cars and 13cm on later cars). hope this helps bud
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
Post Thu Sep 14, 2006 11:40 pm
Mark the front and back sections of the prop, so that after you split it in half and replace the bearing, you can put it togeth with the same splines mating together.
Important, as the prop has been balanced as a whole shaft. Get it wrong and it may be out of balance and vibrate.
Dan318-is
Post Thu Sep 14, 2006 11:43 pm
md-tech, i did one of these the other day and im not the most mechanically minded of people but it really is easy one you see it.
good guide here:
http://www.esatclear.ie/~bpurcell/318is ... #propshaft
Ps i used no pullers etc just wd40 a hammer and the usual socketts
fowler
Boost Junkie
Post Thu Sep 14, 2006 11:52 pm
i have done it in situ but hard work best to do off the car oh yeah wd 40 up those 17mm nuts on the prop
EX A-Tech Workshop bitch !!!
gone but not forgotten
