Just had a quick look expecting to find no fluid or no belt but both are present and correct. Raised the front end to bleed the system but the fluid level didn't fall enough to warrant topping up.
The pump isn't making any noises at all, not even on full lock but after bleeding the PAS returned for a few seconds (enough to get out of the car park) but disappeared again straight away.
Obviously there's something wrong with the pump or rack which is going to take some investigating but in the meantime, and assuming its the pump, how can I ensure that I don't damage the new rack ?
