power steering ?
darlofil
ive manual steering on my 320i ... is it plauseable to take the power steering from a 320se n plonk it straingt on to mine... and if so is it a big job ? ............ cheers phil
Easy enough. You need rack, coupling to steering column, resevoir, pump, altenator/pump mounting bracket, pulley that bolts onto the crank pulley, belt and all pipes.
Bend the lower part of the rack mounting brackets down a little to get the rack in.
dazleeds
- old skool raver
exactly as brian said
beat me to it
beat me to it
www.oldskoolfantasy.co.uk
darlofil
cool thanks guys....phil
