eyebrows
noney82
Post Wed Sep 06, 2006 9:41 pm
iv just got some eyebrows off a mate whats the best way to fit them?
e36boy
Post Wed Sep 06, 2006 10:11 pm
Ive heard of some people fitting them with sticking tape !!!!
FBF
Post Wed Sep 06, 2006 10:14 pm
they recommend glue. id probably try no more nails thats stuffs great but will make a mess if you want to remove them again. i will be using self tapping screws and a pilot hole for mine so i can remove them if i want.. i would have fitted them today but got sent two left side eyebrows.. 8O
im so sexy justin brought me back 5 times
Steviec
Mine are screwed in from the top, 2 small screws on each, does the job.
<a><IMG></a>
dazleeds
old skool raver
old skool raver
Post Wed Sep 06, 2006 10:21 pm
FBF wrote: i would have fitted them today but got sent two left side eyebrows.. 8O
should have put one on and made it look moody :D
mine are glued on but dnt know how
www.oldskoolfantasy.co.uk
noney82
Post Wed Sep 06, 2006 10:25 pm
i might try the screw option in case i ever want to take them off at some point cheers all, where can i get hold of the clips to fit m tech2 front valence?
dazleeds
old skool raver
old skool raver
Post Wed Sep 06, 2006 10:27 pm
noney82 wrote:i might try the screw option in case i ever want to take them off at some point cheers all, where can i get hold of the clips to fit m tech2 front valence?
dealer for the clips
noney82
Post Wed Sep 06, 2006 11:51 pm
do main dealers still stock them?
FBF
Post Thu Sep 07, 2006 5:40 pm
**stop press**
tried to fit one side today. mine are the fibre glass ones. without taking the bonnet off theres not enough room to get the drill in the area for a pilot hole. ended up cracking the brow.. im going with grip fix (thank the BMW lord that i was semt two the same)
ed325i
Post Thu Sep 07, 2006 5:57 pm
Remove the grill, fix the brow and then refit the grill.
noney82
Post Thu Sep 07, 2006 6:01 pm
sounds like an easy optin dont it i'll try that one cheers
FBF
Post Thu Sep 07, 2006 8:37 pm
you sir, are clever.. winkeye
Ziggy
Post Thu Sep 07, 2006 9:39 pm
Remove the rear bumper, glue em on the inside, refit. If you must. :wink:
noney82
Post Thu Sep 07, 2006 10:15 pm
well i took the grill off and drilled them on 10 min job easy
stuartgallafant
Post Thu Sep 07, 2006 10:33 pm
i drilled and screwed mine on
FBF
Post Thu Sep 07, 2006 10:56 pm
come on then noney. pictures!!
noney82
Post Sat Sep 09, 2006 1:02 am
dont know how to do pics help
