17"s on my sport ???
MadE30mike
think the profile of the tyre may be a tiny bit too much fella, but not 100% on that
i had 17" alpina reps when I had the 325, never ever had any rubbing probs with 205/40/17 tyres. Edit: this was with a 60/40 drop
You need to check the offset is correct for e30 too as that may put the tyre near the lip on the arch
MadE30mike
orangecurry
offset for any 7inch rim would be the same as your 15" 7J BBS - around 25 (if I've got my head around offset at last
205/45/17 gives the 'correct' rolling diameter, not 40 profile, but once you lower the car...... who knows? I'm sure someone who's done it can tell you.
I'm only going to mention this once... lowering and fitting 17s will ruin your E30s handling. Do a search if you don't believe me.
Turbo-Brown
- Boost Junkie
The offset can vary with the diameter as the bits a 7J15 wheel would hit with say an ET30 offset are out of the way on a 7J17 wheel.
MadE30mike
orangecurry
don't understand...Turbo-Brown wrote:The offset can vary with the diameter as the bits a 7J15 wheel would hit with say an ET30 offset are out of the way on a 7J17 wheel.
what 'bits' are these?
if the tyre rubs on the inner arch or outer arch due to being the wrong offset, then that'll happen if the wheel/tyre is 205/55/15 or 205/45/17
Turbo-Brown
- Boost Junkie
I'm referring to things like the struts at the front which slope away from the wheel as it gets bigger meaning you can run more of an offset(moving the wheel away from the bodywork) given a larger rim size (ooh err)
bigpimpin
I'd run with 40 profiles on 17"s
just go 16's and have the best of both worlds
dazleeds
- old skool raver
i agreeSimon13 wrote:just go 16's and have the best of both worlds
my 17s are a pain in the arse
totaly spoil any chance of ride comfort etc
www.oldskoolfantasy.co.uk
ian332isport
Bit of a sweeping statementorangecurry wrote:I'm only going to mention this once... lowering and fitting 17s will ruin your E30s handling. Do a search if you don't believe me.
My car is running 17's & lowered. It handles just fine thanks
Ian.
Pal318is
Second That..ian332isport wrote:Bit of a sweeping statementorangecurry wrote:I'm only going to mention this once... lowering and fitting 17s will ruin your E30s handling. Do a search if you don't believe me.![]()
My car is running 17's & lowered. It handles just fine thanks![]()
Ian.
Pal
Pal
[img]http://
[img]http://
Turbo-Brown
- Boost Junkie
Third here!
It doesn't even seem to have effected the ride!
Pal318is
Actually thinking about it
what about Scott players car?? he's got 19" mothers on there! Was speaking to him at Gaydon and he said that he had no issues whatsoever with the size..
Pal
Pal
Pal
[img]http://
[img]http://
cass1_5503
mines fine too no problems and comfort aint to bad either considering my car has been lowerd 60mm i would stick with a 40 profile, with mine being so low i had to have the arches rolled thoPal318is wrote:Second That..ian332isport wrote:Bit of a sweeping statementorangecurry wrote:I'm only going to mention this once... lowering and fitting 17s will ruin your E30s handling. Do a search if you don't believe me.![]()
Ian.
Pal
