can 1 turbo my 320 with this?
darlofil
Post Wed Sep 06, 2006 7:34 pm
i got this off ebay is it plauseable to use it to turbo my e30? has any1 else done it here?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %26fvi%3D1
...................phil
kam-325i
Post Wed Sep 06, 2006 7:52 pm
Its a start !!!!
I think that the manifold has to be mounted upside down, but it will fit with some enlarging of the holes...
darlofil
Post Wed Sep 06, 2006 8:14 pm
:mad: sweet i need to source a lot more parts tho (on a budget tho) :P
Turbo-Brown
Boost Junkie
Post Wed Sep 06, 2006 8:52 pm
You win it in the end? :D
Think you're gonna need a bigger turbo :cool:
darlofil
Post Wed Sep 06, 2006 8:53 pm
yup its in my garage right now hee hee :mad:
fuzzy
He who sleeps with "Gingers"
Post Wed Sep 06, 2006 8:54 pm
for Ԛ£85 i suppose you cant really go wrong but dont diesel turbos tend to be quite small?like already said though its a start winkeye
maxfield
Post Wed Sep 06, 2006 8:56 pm
less lag :wink:
kam-325i
Post Wed Sep 06, 2006 8:57 pm
Connecting the air intake to the heater blower would help out a 320i !!!!! :cry:
Smaller turbo would be a good start, less lag ?
Turbo-Brown
Boost Junkie
Post Wed Sep 06, 2006 9:01 pm
There's smaller and then there's too small though.
There's quite a likelyhood that the materials used in the construction of the exhaust housing won't be fond of the heat generated by the petrol engine too :(
fuzzy
Post Wed Sep 06, 2006 9:07 pm
arent diesel turbos a different set up as well? i was told a while back that dump valves dont work on them for example.dont know if thats true or not though but im sure someone will correct me shortly i expect winkeye
Turbo-Brown
Boost Junkie
Post Wed Sep 06, 2006 9:15 pm
Think that's only when they're attached to a diesel engine.
The basic workings of the turbocharger are the same for both petrol and diesel applications.
kam-325i
Post Wed Sep 06, 2006 10:13 pm
fuzzy wrote:arent diesel turbos a different set up as well? i was told a while back that dump valves dont work on them for example.
The local chavs around here dont seem to care....Theres no end of 309's and Escorts diesels with dump valves aroun here........
Clak Clak Clak Clak Clak Clak Clak Clak Clak Clak Clak Clak Pssst......
darlofil
Post Thu Sep 07, 2006 5:41 am
i was hopeing that using a small turbo would still give a good boost but still be able to run on a stock engine for the time being ..........phil
e30_Turbo
Boost Junkie
Post Thu Sep 07, 2006 9:09 am
Diesel turbo's work fine on petrol engines but getting the right sized one is critical or you'll only get frustrated, i.e too small = no top end or too big = no bottom/midrange.
T3 on M20B25 is about as small as you should go, unless you're greedy and have two like Alex :D
That baby piss TD turbo needs going back on ebay and get yourself something a bit bigger, std cossie turbo would be a huge improvement for sure!
HTH, Mark.
gcorky
Boost Junkie
Post Thu Sep 07, 2006 10:32 am
fozzymonster wrote:Diesel turbo's work fine on petrol engines but getting the right sized one is critical or you'll only get frustrated, i.e too small = no top end or too big = no bottom/midrange.
HTH, Mark.
nout like bein blunt-i say what i like an i like what i say!get something better m8.
525 sport
