Hi guys,
me and a mate are gonna have a bash at fitting my cruise control tomorrow, have just been looking through the bits i got and it seems i only have a clutch switch and not a brake switch. as the clutch switch isnt needed (my car is auto) can it be doctored and used as the brake switch?
also my speedo isn't currently working, as the cruise control takes a pulse from the speedo will the fact that mine doesn't work stop the cruise from working??
cheers
Matt.
cruise control questions
matttouring
'89 320i Touring 'Switchable' Auto Colour: Dirty
gcorky
- Boost Junkie
senses brake depression through system without need for switch m8-just bridge the clucth switch wiring.
r.e depends what is wrong with your speedo m8-takes the signal from the downward facing accessorie socket which isnt usually fitted -have you got it???
ive got a spare if you need one?its a green socket that slots to cluster from bottom?
gcorky
- Boost Junkie
matttouring
have you got a pick of where this goes bud cos i have got a green plug on the back of my clocks not sure if it the 1 u talk aboutgcorky wrote: r.e depends what is wrong with your speedo m8-takes the signal from the downward facing accessorie socket which isnt usually fitted -have you got it???
Speedo does work now and again think it just a break in the wiring really do need to get it sorted though
Matt
tomson
Matt, i got your pm buddy and in truth i have no idea!
Is it not clear in that retro fit guide i forwarded onto you mate?
Id ask someone like brianmoore, he's bound to know
cass1_5503
ther should be a brake switch already fitted which turns on the lights as for the clutch switch all i did was cut the switch off and joined the wires together with a crimp connector hope this helps
DJ_B4L
im looking to do the same thing install a cruise control to a auto i just wana check i ant missing any parts
i got the stalk
the steering colum surround
the wiring loom
the atculator
any thing else that i should have and how can i install this to my car would it work on a 1.8i
i got the stalk
the wiring loom
the atculator
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
The cruise control isn't going to work until you sort the speedo, which is probably an internal break in the wire from the diff, within a couple of inches from the plug.
If you look at the back of the instrument cluster, on the underside of the speedo part, you will see five small holes in a line, with a couple of plastic hooks either side.
This is where the green socket fits. All that is missing is the piece of green plastic itself; the sockets for the connector are already there, and most of them are the speed signal. Just push 4mm of bare wire into the socket.
The speed signal is also available at pin 10 (blue/yellow wire) of the white connector.
