9 inch wide 16's. help.
ackerley
Thu Aug 31, 2006 11:19 pm
hi all,
im thinking of going for some borbet alloys. 16x9's, and a 60 40 drop.
are these going to go straight on or would i be better getting 8 inch wide.
i really dont wont to have to mod the arches in any way.
any help or advise is mostly appreciated.
thanks guys n girls
ianeire
Fri Sep 01, 2006 12:19 am
I had a a set of 9x16 under my 60/40 drop the other night and while they didnt fit right due to the offset being wrong.... you will have to roll the rear arches. The arch came right down to the top of the stretched tyre with only a couple of mill of room. Any bump and you'll be scrubbing big time. I dont imagine arch rolling is too expensive though.
9's look sooooo much better than 8's! Get the 9's and enquire about getting the arches rolled!
1990 Brilliantred 325i Sport
www.e30owners.com Irish e30
ackerley
Fri Sep 01, 2006 10:11 am
what offset would be best?
and what if i went for 15x9's would these still need arch work?
Taxin
Fri Sep 01, 2006 10:41 am
To get 9's to fit roll all 4 arches and make the car rock hard using Adjustable shocks and bump stops :cool:
egk2
Sun Sep 03, 2006 2:44 am
You need 16x9 et15 with at least a 5mm spacer in the front just to clear
the strut housings, the rears go right on but you may want to run
a 10mm spacer to even out the track, tires should be 215/40/16.
The rear arches will need to be rolled flat which is not a big deal and the front can be left untouched.
2.8L M20 Stroker
ackerley
Sun Sep 03, 2006 8:10 pm
is this an expensive job, or can i do it myself??
cheers for the help
basil
Sun Sep 03, 2006 9:18 pm
i got 9x16 keskins on the bac of my cab no probs with a 40mm drop and et15 offset no scrubbing or anything even fully loaded just had to get 5mm spacers for the front to thinking about trying to get 10s on the bac
egk2
Mon Sep 04, 2006 1:06 am
cheers for the help
You should be fine with no spacers in the rear, rolling is a simple
procedure if you have a fender roller, most bodyshops can do it,
I was charged $40usd per arch. You can do it yourself by renting the tool or you can do it the ghetto way with a wooden baseball bat.
Click on the link for fender roller info:
http://images.google.com/imgres?imgurl= ... n%26sa%3DX
2.8L M20 Stroker
TheRealest
Mon Sep 04, 2006 1:31 am
i got 9's on the rear, i think rubbin all depends on how low ur car is and how hard the suspension is, mine rubbed bad but not anymore
