OK guys, I'm a little 'tired' at the mo, but I have a question re the early (external) fuel pump - mine has failed the MOT because it's loose, but closer inspection reveals it to be fastened to absolutely nowt (bar the actual pipes). There is a bracket around the pump, which has matching bolting points on the bodywork, but here's the dodgy bit - there are rubber stops bolted to all these points, and these merely bounce together under vibration - it has clearly and DELIBERATELY not been attached to anything for some years.
So, in short, I've locked it together with a couple of cable ties - it's more secure, but will this pass muster on the retest? A long shot I suppose, but if anyone has any experience of the above...
PS MOT station is known to be reasonable, they wouldn't have flagged this up if it was marginal.
Fuel pump loose - MOT fail...
kidsinister
- Homo Hair
i use zip ties to do summat similar a while back on my old GSi.. Should be fine
Templ8e30
http://www.realoem.com/bmw/showparts.do ... g=16&fg=15
Are these the bits you're after ? number 4 and 5 ?
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
kidsinister
