Help urgently... car keeps going after key is taken out.
Stevin
Post Wed Aug 30, 2006 7:31 am
Help me... I dont know what is going on.
When I turn the car off and take the key out... the car just stays on.
If I stall the car to get it to go off, all the electrics stay on... the the Istrument Cluster, the check lights... etc
If I try and turn it on... the car blows the hooter, and starts (well sometimes it starts, othertimes it just blows the hooter)
No matter what postion the key is in, the electrics stay on.
I thought it might be the ignition switch but it wasn't that...
Help me pls... I'm desperate. I need the car for 2morrow evening.
E30Mark
Post Wed Aug 30, 2006 7:56 am
Sounds like a fault with the OBC (on board computer), pull the wiring to the OBC and see if the problem stops...
There is an article here that tells you how to retrofit the OBC so it might give you some pointers on how to disconnect it! unfortunately there are no photo's ...
http://www.e30zone.co.uk/modules.php?na ... troobc.htm
PM for details
andyborris
Post Wed Aug 30, 2006 7:59 am
Sounds like the ignition is grounding via the horn, try disconnecting the horn or the horn relay if you have one. If that cures it, you've got a short in the horn circuit somewhere.
Andy
Stevin
Post Wed Aug 30, 2006 8:00 am
How would the OBC control the electricals ?
I should add, that this started after some racing at our local strip... car was fine after my run. When I got home, it wouldnt switch off.
E30Mark
Post Wed Aug 30, 2006 8:08 am
Stevin wrote:How would the OBC control the electricals ?
I know if the the OBC is retro fitted sometimes you can't turn the engine off! you have to leave some of the wiring disconnected to stop the engine, happened to me!
Try pulling the fuses / relays and see which one causes the engine to stall, go from there...
PM for details
Stevin
Post Wed Aug 30, 2006 8:11 am
OBC came with the car... sorry should said what car it is. It's a 325i MEX , with a 2.9lt stroker. still running stock ECU.
I'll have a look at the horn... think it could be anythign else ?
Stevin
Post Wed Aug 30, 2006 8:13 am
Does anyoen have a schematic of the Relays... I couldnt find one
E30Mark
Post Wed Aug 30, 2006 8:20 am
Stevin wrote:Does anyoen have a schematic of the Relays... I couldnt find one
time to learn Russian!
http://www.autolib.diakom.ru/CAR/BMW/ :D
PM for details
Stevin
Post Wed Aug 30, 2006 8:35 am
Thanks man... Sheesh time start studying.
Bleh, I hate electrics.
Fushion_Julz
Post Wed Aug 30, 2006 9:51 am
Sounds like a faulty ignition switch, TBH....maybe a poor connection such as the BAT live shorting to the ACC live terminal, but more likely to be the switch.....
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Martinaston
Post Wed Aug 30, 2006 10:56 am
Could be an old alarm thats hidden away somewhere, if not then check the ignition relay and go over the engine loom to see if anything has melted. The last two don't explain the horn sounding though :?
There is NO nucleus.
boomer
Post Wed Aug 30, 2006 11:03 am
Happen to my old man many years ago in his landcruiser - turned out to be that the starter motor had shorted out internally.
may be worth checking
Morat
Who stole Brianmoore? Have we finally exhausted his patience?
E30Mark
Post Wed Aug 30, 2006 11:07 am
Morat wrote:Who stole Brianmoore? Have we finally exhausted his patience?
He has been away on Holiday, he is back but having PC issues!!!
PM for details
Morat
Post Wed Aug 30, 2006 12:12 pm
phew, don't want to lose him from the zone!
I can do computers... its my job. Tell him to call/pm me if he's really stuck!
Morat
Stevin
Post Thu Aug 31, 2006 7:40 am
So I got home and put the whole underside of the steering colum back 2gether. Checked all the relays and what not... pulled the one out that says on the wiring diagram "hi-speed relay" ... and all the electrics switch off. Ok, cool. But then I pushed down on the fuse box, and everything came back on, until I stopped pushing... So. I found the problem... but when I put the relay back in everything was 100% , but there must still be something wrong inside the fuse box.
Oh well, at least I know where it is... so I can go racing 2nite.
Thanks 4 the help guys.
