My battery wasn't getting charged at first - turned out to be a duff battery!
Have you tried using the coolant bleed screw on top of the thermostat housing? I can't say if this is easier because mine sheared off, I bled it through the expansion tank, it overheated and burst the radiator!
Still trying to find a replacement, but I did get another stat housing with a working bleed screw.
I had to remove (drill out) one manifold stud as it hit the steering coupling, just used nut and bolt. I have used the springs but agree they are probably not necessary.
I fitted an E36 steering rack so had to modify the front manifold (by cutting and re-welding the steel part) and so then had to re-shape (cut and weld) the downpipes completely. Then I made my own pipes up to the rear silencer. A bit Mad Max and noisy but I don't mind that!
