325i Running Cold
Riley
Post Mon Aug 28, 2006 10:05 pm
i have a 1991 325i motorsport and the temp gauge does not get up to the centre, i have just replaced the thermostat, but it has made no difference. does anyone know why it is running cold?
E30 325i Motorsport Convertible Calypso Red
E46 330d Sport Touring Imola Red
kam-325i
Post Mon Aug 28, 2006 10:17 pm
How far up does the needle go ?
Just below halfway is normal...
Riley
Post Mon Aug 28, 2006 10:21 pm
about half way between centre and the mark before. How can that be normal? surely centre is normal?
kam-325i
Post Mon Aug 28, 2006 10:29 pm
Anywhere just above the quater mark and upto the halfway mark is "Normal". Mine runs just below halfway. But if i am driving hard i can get it to just go over halfway....
If all things are ideal......then halfway is normal....but they are not......
stevetigger
Post Mon Aug 28, 2006 10:41 pm
I once owed a 325i Sport that always run at 1/4, never did me harm!
Morat
Post Tue Aug 29, 2006 10:16 am
What we're saying is that the gauge is often a lying git. If you're worried about the temp your engine is running at then you're probably going to have to investigate the gauge first, then fix any problems that come to light.
pnd
Post Tue Aug 29, 2006 10:21 am
The difference between a quarter and halfway is tiny in temperature terms also there are different thermostats. Given the choice I'd prefer lower than halfway.
Fushion_Julz
Post Tue Aug 29, 2006 10:27 am
Sounds like either the gauge isn't very accuarate or the sender is giving dodgy readings....
I bought one of these http://www.maplin.co.uk/module.aspx?Tab ... 3&doy=29m8
(only they were half price last month) and it shows the temperature accuarately on the sender and at any point on the cooling system so you can see if the gauge is inaccuarate or not...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Riley
Post Tue Aug 29, 2006 10:32 am
What is the correct temperature menat to be anyway?
Fushion_Julz
Post Tue Aug 29, 2006 11:01 am
From memory....Thermostat starts to open @ 82C fully open @ 92C
I would expect around 92-99C at "normal" with a fully warmed up motor at the top (inlet) of the rad and significantly cooler at the outlet...
And no major hotspots on any part of the water jacket....
Can't recall what the presurisation factor of the system is, but I wouldn't be expecting to see a boiling coolent (assuming you have the correct coolect cap and the correct amount of antifreeze in the ssytem) until 108C at least....
kam-325i
Post Tue Aug 29, 2006 11:01 pm
Fushion_Julz wrote:what the presurisation factor of the system is
The wierd effect that cause's a higher boiling point of water/water mix.....
Fushion_Julz
Post Tue Aug 29, 2006 11:06 pm
cheers, Kam...what I meant was I can't remember how much the system gets pressurised by...or, in other words, how high the new boiling point of the presurrised system is!
:mad:
kam-325i
Post Tue Aug 29, 2006 11:13 pm
If i remmeber rightly, (but dont qutoe me !!!)the boiling point of a "normal" summer water/anti-freeze mix in a M20 is 110°C, so you was not far off.....
Fushion_Julz
Post Tue Aug 29, 2006 11:21 pm
cooool...my memory isn't so bad after all!!
(or yours is as bad as mine :D )
