for some reason the readout display on the dashpanel dont light up any more?? it has done this once before then started to work again? could it be as simple as a bulb?
has any one else ever had this problem? and how did you sort it?
OBC DISPLAY
drewjak
Steviec
It prob is just a bulb.
Is it the 6 or 13 button obc?
The 6 button is easy, release the unit from the front and change the bulbs at the rear.
13 button one is harder and you may need to remove the heater panel. Once the obc is accessable, you will see a white section in the side, this is the light bar, you need to remove this and either: buy a new unit from BMW (about £25) or solder 2 new bulbs in (about 12p from Maplins).
Hope this helps.
Hope this helps.
<a><IMG></a>
drewjak
excellent , i had a feeling the 13 would be a little more difficult, but nevermind . it needs sorting
cheers
cheers
Badboyoutlaw
Its not that hard bro! Today myself and my girlfriend changed the LED,s on her 318is obc just make sure you put the led,s in the right way if you get them from maplins!!! Dont no about 12p each on the led,s ? We payed £2 for two....drewjak wrote:excellent , i had a feeling the 13 would be a little more difficult, but nevermind . it needs sorting
cheers
lol
Badboyoutlaw
Dont need to take out the heater panel bro, Just take out your set and get to the two screws inside! Then undo and push the obc back untill you can pull the bulb holder out! Solder in the new led put back and JD....Steviec wrote:It prob is just a bulb.
Hope this helps.
drewjak
ive eventually got round to doing the job this morning,not a bad job to do if ya dont mind gettin poked in the ribs by the seat belt holders a few times. i did,t replace the bulbs as such,but had a freebie led strip from a mag(supposed to go under door handles) which fitted in the slot perfectly, so just wired it to the radio ignition live. works a treat, and would say cheaper than a new part and less fiddly than replacing bulbs.
but thanks for your info guys it was a great help, i wouldt have known where to start getting it lit back up again.
oze30
What wires/where di you splice into?drewjak wrote:ive eventually got round to doing the job this morning,not a bad job to do if ya dont mind gettin poked in the ribs by the seat belt holders a few times. i did,t replace the bulbs as such,but had a freebie led strip from a mag(supposed to go under door handles) which fitted in the slot perfectly, so just wired it to the radio ignition live. works a treat, and would say cheaper than a new part and less fiddly than replacing bulbs.
drewjak
i used the ignition live from the back of the radio m8, off hand i could`t tell you the colour of the wires sorry.
