My front jacking points just disintegrated. Does anyone know if new ones are still being made? Or has anyone happened to cut some out of a crash-damaged E30, as I'm guessing most E30s at the scrappies will rusted to f@$k anyway.
Any ideas on what to do would be appreciated, as it looks like an MOT failure otherwise.
Cheers, Ian
Rust rust rust
ad318i
weld!
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
alan325i
i had mine welded a week ago, they tend to just grind off the old jacking point and just weld a plate on.
Doubt anyone uses the jacking points anyway, well you dont, or your jack would of ended up in the footwell it they were that bad
Gwynleym10
they are not jacking points, just where the shell was carried around in the factory. the chassis rail is where you should jack the car up.
this is why so many e30's are so rusty here, because they are being used for something they are not desingnd for.
just weld a plate there
