bumper mounts?
gilb
any1 no if you can change the front bumper mounts (the big parts) mines a bit crumpled on one side where sum numptys bummped it
smithy318i
simple answer is, yes.
long answer is... two t55 torx bolts hold the bumper to the body. two 13mm bolts hold each mount to the body.
ultra easy to replace.
gilb
yeah i no that its the bit after where the bolts mount 2 basically the chassis arm at the end
