how do touring rear seats come out?
gareth
Post Sun Mar 20, 2005 12:09 am
i have got a rear headrest conversion (off ebay a while ago) which i want to fit to my touring.
how do the rear seats come out? i'm baffled!
gorgeee
Post Sun Mar 20, 2005 1:19 am
hi not fully sure but ive dont this twice but cant remember fully but as no 1 else has replied -
you can pull the rear seats down and then they theres a thich metal plate that goes across the bottom of the seat this needs to be lifted up slightly on both sides and the seat will pop out there may be a lever or little piece of metal you need to prise outwards before you can lift the seat.but gernerally the seats need to be lifted upwards from the base where it mounts to the body of the car.
base units you probably know just squeeze 2 holes inwards and the side bolsters have a screw at the bottom of them and then these also need to be lifted up.
hope this helps
Black Sport
KDS
Post Sun Mar 20, 2005 2:19 am
Rear seat backs in Tourings have a pressed steel panel as a structural backing. The upholstered seat back is hooked onto this and can be removed by simply sliding it up towards the ceiling. Dead simple. This should give you the access you need to mount your cool new headrests.
There might be a fastener at the base that holds the cushion in place, but it should be pretty obvious. You may need to flip the seat bottom cushions forward for easier access.
-KDS in Vancouver ('88 325i Touring)
Post Sun Mar 20, 2005 9:40 am
There's no fastener at the bottom of the seat backs - it's two spring clips. Pull forward before lifting, and don't get blood on the fabric.
Don't know how much you paid fot headrest kit, but on a Touring the parts are the same as the front seats.
gareth
Post Sun Mar 20, 2005 10:13 am
cool! i was expecting to have to remove the whole lot!
excellent!
the headrests only cost me Ԛ£15 delivered, not bad as they are mint with all brackets and plastic trim thingies and match my touring-sport interior!
thanks for the help guys!
gorgeee
Post Sun Mar 20, 2005 8:36 pm
where do you get the headrests from ?
Black Sport
Post Sun Mar 20, 2005 9:07 pm
Front seats of a scrapper with same trim. OP got his off ebay.
gorgeee
Post Mon Mar 21, 2005 2:26 pm
easy to fit ?
i got leathers in my touring will this be the same for them,but i just get headrest from front leather seats ?
Black Sport
gareth
Post Mon Mar 21, 2005 5:50 pm
very easy! i did it yesterday and it took about half an hour!
it now looks the nuts!
it's a bit tricky working out how/where to pull on the seats but once the first clip goes then it's obvious.
andyp
True Old Skooler
Post Wed Mar 23, 2005 7:31 pm
I am trying to do this now, ive got the carpet panel off the back of the seat and there is a big metal panel so i cant get access to the metal holes to fit the kit, ive got leather in my touring { dont no if it makes a difference} but looks like it anybody ?
KDS
Post Wed Mar 23, 2005 7:37 pm
You don't go in from the back (carpeted) side--go in from the front. Just remove the seat back cushion and you should be set!
andyp
True Old Skooler
Post Wed Mar 23, 2005 7:40 pm
so what you are saying is ive got to take the leather off, or does the whole seat somehow come away from the frame
KDS
Post Wed Mar 23, 2005 7:49 pm
Pull the entire leather seat back off, as described in my post further up. Cheers.
gareth
Post Wed Mar 23, 2005 8:15 pm
grab hold of the bottom of the seat back "pad" part and pull it towards the front of the car. it's held on with lots of plastic clips. make sure the bottom of the seat is folded forwards!
when one of the flips pops out, it'll all be sickeningly obvious! it took me an hour or two of feeloing stupid before i asked on here, and another half hour to work out how to get them off!
andyp
True Old Skooler
Post Wed Mar 23, 2005 10:01 pm
yep piece of cake when you know how, cheers boys had sir B on the other end of the phone telling me, cant believe it is so easy, ALSO caught the end of me fingers and yes it hurt.
Post Wed Mar 23, 2005 10:34 pm
Warned you on my earlier post not to get blood on the fabric. Been there, done that.
andyp
True Old Skooler
Post Thu Mar 24, 2005 1:43 am
yeah i know you did cos when the first seat came apart i thought of you and { thought whats he on about } when i did the second seat i found out
