lsd (e30)
midnight
Post Wed Aug 23, 2006 7:56 pm
whats the difference in differential lock between the m3 diff and the 325i, beacause i have heard the 325 is only a 25%lock, any help much appreciated
jmc330i
Post Wed Aug 23, 2006 7:57 pm
M3 is 25% IIRC
James
'91 325i Sport
'93 318i touring 16v
midnight
Post Wed Aug 23, 2006 8:03 pm
so they are pretty much the same then?
jmc330i
Post Thu Aug 24, 2006 8:21 pm
Different ratios - 325i is normally 3.91lsd, theres also the 3.64.
The M3 is 3.25. (3.15 on one of the models)
James
'91 325i Sport
Evo III thingy was 3.15
MikeeMiracle
Post Fri Aug 25, 2006 8:31 am
The ratio is all important also, you don't wanna just look at the diff lock. My 318iS came with a 4.1 open diff, I thought I had fitted a 3.91 lsd but it turned out to be a 3.64 lsd. The longer ratio has lost a lot of performance, a second to 60mph easy. I now have tons of traction but not enough power going to the rear end to break it out easily. :(
Red 318is
Take me to the land of the twisty's :)
midnight
Post Sat Aug 26, 2006 10:23 am
so what diff would you reccomend, with good traction, but will break out when required>?
MikeeMiracle
Post Sat Aug 26, 2006 3:54 pm
Depends what car you have?
Red 318is
maxfield
Post Sat Aug 26, 2006 4:05 pm
Was 3.15 on all EVOs
midnight
Post Tue Aug 29, 2006 3:15 pm
ive got a 320iSe at the mo, but an engine transplant mite be on the cards in the future
