New h/u with motorized screen, finally in..............
miniblob
Post Thu Aug 24, 2006 5:30 pm
Woo hoo!!!!!
Just got my head unit fitted in time for Gaydon.
It's a Sony XAV-A1 with 7" motorized screen!!
Had to put in a lhd centre panel to give it space for the screen to fold out. Lhd panel isn't an exact fit, but it will do for now!!
327 Touring with bass!!!
blingsta
Boost Junkie
Post Thu Aug 24, 2006 6:34 pm
just some advice matey.. ive got one of these wonderful things.... make sure the heater vents are switched off if the hot air is on.....
miniblob
Post Thu Aug 24, 2006 6:43 pm
Ha ha, will do!!!
I suddenly thought of that the other night!!
maxfield
Post Thu Aug 24, 2006 6:45 pm
If you ever get pulled with this up. £30 fine winkeye Looks great.
e30bemer
Nutters
Nutters
Post Fri Aug 25, 2006 2:45 pm
The feds never leave us in peace do they!
Any excuse to squeeze more money out of us!
:x
mikey-t
Post Fri Aug 25, 2006 2:49 pm
stilll legendary episode of t` fools and horses
miniblob
Post Fri Aug 25, 2006 3:00 pm
maxfield wrote:If you ever get pulled with this up. £30 fine winkeye Looks great.
Really!! That's cheap for a fine :mad:
I've tried to fit it on a switch so it works off the handbrake as it should at the touch of a button, but it doesn't wanna work at the mo!!
It would appear foglight switches aren't the straight make/brake they appear to be!! :cry:
I'll find a way though!!
Mikey - they're all legendary!! Got the whole lot!!
cliffybabe
Powered by Nelly
Powered by Nelly
Rob saw ur car at Gaydon next to Sal's stand looking good mate
I do like the left hand drive centre consol winkeye
mikey-t
Post Fri Aug 25, 2006 3:04 pm
my mate mounted a switch at the lowest point of handbrake drop, so when hanbrake off it wont work but you could have it working while driving if you lifted the brake a little bit as the handbrake didnt bind for a good 4 inches or so of lift
miniblob
Post Fri Aug 25, 2006 3:31 pm
Cheers mate - lhd panel almost fits!!
Mikey - I've used the twin fog light switch, one connection on each switch goes to the h/u and then the other of one switch is to earth and the other to the handbrake switch as it should be. One switch means it works all the time and the other means it works off the handbrake!!
Got a standard size hole for it already where the window cutoff switch was so i wanted a standard switch to replace it!
Like i say though, that switch doesn't seem to be a straight make/brake. All wiring is good, if i disconnect one cable and touch it on the other pin it works fine, but the switch don't seem to do anything!! Tried a few switches too so i know it's not just a dodgy one!!
Have to get my meter out again and do some more investigating when i get a chance!
Might be easier to just put in an aftermarket switch!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Aug 25, 2006 3:42 pm
Ground out the interlock and it does the same job winkeye
blingsta
Boost Junkie
Post Fri Aug 25, 2006 4:06 pm
yep, just earth the wire and it works whenever you want
miniblob
Post Fri Aug 25, 2006 4:19 pm
Yeah, i know - that's what one switch does - but i was trying to be clever so i can also have it working off the handbrake as it should at the touch of a button!! Might come in usefull, maybe if i get pulled!
mikey-t
Post Fri Aug 25, 2006 4:20 pm
better than my "pull the nearest lead" method
miniblob
Post Fri Aug 25, 2006 4:28 pm
Ha ha, that's what i'm using at the mo!!
