LSD for 316i
Cromanian
Wed Aug 23, 2006 8:48 pm
Whats the best LSD ratio for a 316i 1989, whenI say best I mean for going round and round and round but I'm sure you all know that.
Cheers Daniel
Davenotouring
Wed Aug 23, 2006 11:28 pm
A 3.91 would be ok.
BMW 328i Cab - Daily Slag
Cromanian
Thu Aug 24, 2006 6:23 pm
Cheers Dave
kevin316i
Thu Aug 24, 2006 11:02 pm
A 3.91 is only OK, I had one in my previous car a 1990 316i. Because the 316i doesn't have much poke, you will notice the difference in ratios. The standard ratio is 4.10 so you need to balance you need for a LSD against the effect of the different ratio on your acceleration and driveability. You should try to hold out for a 4.10 LSD and preferably a small casing one, as there is no point in carrying around the extra weight from a large casing diff in a small engined E30. And don't forget to use the correct limited slip diff oil - Castrol SAF-XJ from tha main dealers. :wink:
Cromanian
Wed Aug 30, 2006 8:37 pm
Cheers Kevin
